Hi peeps, can anybody advise me on a previously removed chimney breast solution. The house is for sale and has just been subject of a structural survey which indicated a problem with a previously removed chimney breast. It was removed prior to our ownership 17 years ago and was removed from ground floor level into the loft space. The bricks are currently supported by gallows brackets either side bolted into the party wall with a 6mm x 100mm x 1200mm metal plate. Over the 17 years in our ownership there has never been any evidence of collapse above the gallows brackets, however the structural engineer for the purchaser has stated the following requirement:
'Carefully prop the chimney stack from roof void to ground floor and replace the existing steel plate and gallows brackets with steel joists calculated to size. Building Regulations Approval Notice must also be obtained.'
So my question is, Should the purchasers structural engineer stipulated the calculated size or is he suggesting I should get my own SE to tell me the size. Is is likely the BC officer will tell me the size?
any help will be much appreciated.
