Hi, Can you tell me if a 15mm stainless steel pipe can be jointed the same way as a copper one; ie can you use a copper solder ring or end feed joining it to copper, also can you use a standard olive on it when using a compression fitting? Also can you use a pipe slice on it? Thanks
