Hello everyone. First off this forum is so helpful loads of info on here.
Anyway to my question. My house built in the 1970's during the copper shortage has been fully plumbed in 22mm stainless.
Now I have just removed it all and done away with the storage tank so the house is all on mains water. But the main stop valve is still attached to stainless and has a strange fitting that dose not use a olive so can't fit direct to this with copper pipe.
I removed the pipe and cut it short so I could put a compression fitting on and then run new copper pipes from this point on but I can't get a good seal. It always weeps from the compression fitting where it's attached to the stainless steel pipe.
If I can't sort this the only other thing I can think of doing is shutting off the water at the street valve and remove the final bit of stainless and fit a new stop valve on to the incoming copper below.
Can anyone advise me on how to seal a compression fitting to stainless.
