Hi all,
Not being a very good week for me so far!
Tonight, I was cooking on the gas hob on my Cannon C60DTC cooker, no problems there. Then a very loud pop and a tripped MCB, not the RCD. I have a brand new CU installed and fully certified to 17th eddition.
Anyway, as the oven wasn't even on I reset the MCB which then caused the RCD to trip.
The cooker is on it's own circuit with nothing else on the same supply. I've tested the cooker isolation switch on the wall, no problem there, I've also had a look at the connection on the back of the cooker there either. I thought that it might be a dodgy oven element, but the ovens or grill weren't in use.
Any ideas? The gas supply is still ok, so at least I can use the hob, but not having an oven or grill is somewhat a pain in the rear!
Thanks in advance!
Thanks in advance!
