Steel Beam on Wall plate
18 Jan 2009
Derbyshire
We are shortly starting a loft conversion and the plans show a number of Steel UB's (on 15mm steel plates instead of Padstones). The steels are supported on the top of the wall under the hipped roof (hipped on all 4 sides).
Is it OK to support the steels on the specified steel plates on top of the existing wooden wall plates (100x75 approx)- or do I somehow need to remove a 300 mm section of wall plate and replace with engineering brick?
Thanks for any advice
You can't sit it on the wallplate, as the load will crush it. You need to cut a section out, replace with spreader plate and steel packers up to the required level.
Thanks for the advice - thats what I suspected....
Do we really need to use steel packers or could we build up with engineering brick and put the 300x100x15mm steel spreader plate on top...?
Yep you can do it that way. You wouldn't actually need the spreader plate then, if you make the eng bricks the same plan area of the plate.
