Step or Jump footing
  • Thread starter Thread starter RD
  • Start date Start date
RD
29 May 2009
Sheffield
I've knocked down the existing garage and rebuilding a longer and wider one myself. I have started digging the footing, the ground is not level therefore I intend to step the footing in three places. My question is this, once I have poured the concrete, after it has dried I'm thinking of using concrete blocks (440X215X100mm) horizontally (100mm thick in the UK) to bring the footing to a level. Can I use concrete blocks? Are they suitable for the job? Or should I be using common bricks? which would be awkward. Obviously the DPM will be couple of bricks above the footing. Any help will be appreciated. The width of the steps will obviously depends on what I'm using to fill the gaps.
Your dpc should be 150mm above ground level.
This may be a daft question but why build on uneven ground, Why not level it first?.
Or is it not level for a reason ?
RD what you're doing is wrong, the bottom of your foundation should be level.
Stepping found's is not a problem so long as you step them in the corresponding increments, i.e. 75mm or 225mm.
Make sure the step overlap affords you full concrete thickness, i.e. when viewed as a cross section from the side the upper concrete step overlaps the lower concrete by at least 450mm.
after you dug out if it looks level it is level concrete levels itself if its mixed correct, why step any way just buy extra concos ,probaly work out cheaper : never seen a guy yet put a level in footing before its concreted 8)
first of thanks for all the advice, I've been busy digging outside and I didn't have the opportunity to check my email until this morning.
Sorry perhaps I should have explained my self better. Your are right the ground in uneven and before I construct the floor I intend to level it. I was talking about the footing, the clay underneath the top soil is not level. If I didn't put steps then I will be pouring in some places over a meter of concrete, which I'm sure everybody will agree will be a waste of money. The size of the new garage will be approximately 8mX4m.
Im sure he meant stepping the top of the footings not the bottom.
You are right I'm thinking of laying concrete blocks side ways on top of the step, so I'm planning on leaving about 110mm (10mm for cement) steps to bring the footing to a level.
I presume your measurements for the increments is based on the size of the material I'm using to bring the step to a level. ie bricks - 65mm + cement 10mm = 75mm. 225 for blocks.
Affirmative.
