sticking lifting corners of lining paper
14 Sep 2009
Hi. I recently hung lining paper on emulsioned and sized walls. Followed all instructions about mixing paste (Solvite), pasting carefully, soaking the paper, etc. Some, but not all, corners have lifted. A few days after hanging I went round and applied more paste to those corners, allowed to soak and then stuck back down. Some, but not all, of the corners are now stuck firmly. Don't know if it's coincidence, but the two corners which have lifted the most (by a window) are where some caulking has been done.
Should I paste the unstuck ones again? Or would I be better with some other approach e.g. border and overlap adhesive?
For what it's worth, I'll be papering over the top of the lining paper in due course.
Thanks,
wrathkeg
There are many things that cause paper not to adhere correctly, but caulk is unlikely to be it assuming you did use decorators caulk and not silicon.
Ultimately what you need to do is stick the paper down; whether you use border adhesive or super glue. Peek behind the lifted corner and make sure the wall is clean and not a gloss finish then use whatever is at hand.
thanks. it was caulk, not silicone. no gloss paint. any thoughts anyone as to whether superglue or border adhesive is more likely to be successful?
Why not use a dab of Decorators caulk smeared on the paper, sticks like the Preverbial to a blanket
thanks for all the suggestions. will probably give PVA a go, as I have some of that lying around.
thanks for the replies, everyone. have used a bit of PVA and everything seems nicely stuck down. great tips.
thanks again.
