Hi
I have a bathroom with a very unsavoury smell. At first I thought it was smell wafting through the window from the top of the soil pipe, however I have eliminated that so I think its caused by the following:
The toilet is T'd into the horizontal soil which extends a about 2 foot passed the toilet and is then terminated. The bath outlet is then bossed into the centre of this termination, I think there is a build up of "solids" in this dead end which is causing the problem. Before I go to a load of work is this likely? If it is I will have to remove the dead end and put a right angle connector in, the problem I then have is attaching the bath waste which does not have any leeway as regarding height any ideas - i'm aiming to completely redo the bathroom next winter does anyone have any suggestions on a temporary fix until then? even if its just a really good chemical I could shove down there ....
many thanks
many thanks
