- Joined
- 22 Aug 2006
- Messages
- 7,844
- Reaction score
- 1,481
- Country
Gold stayed in the channel until it bounced off the red line level . That's what happens at levels. A level is a is a pull - or a resistance or support when the price gets close of course. Theproce is affected by lines and levels, which is called respecting them; not a prediction.
Nauss didn't say bullish for the first three days of the week, did he? What he actually said was "still bullish gold". The video was dated the 8th when gold was 2020. It rose to 2053.
And the FED hadn't spoken. You're going out of your way choose a critical interpretation. Hmm.
By the way I looked at your derogatory comment on what he'd said:
"1. AUD/JPY is in a wedge. It could break out of it above or below. Watch carefully. No doubt it will do one of the two. His chart had a time span of 18 months, so it's going to be a long wait to see which it does. But what is the value of that comment?"
It's a compression pattern, which you should learn about. Why do you say the chart had a timespan of 18 months when he said the breakout "could be some time next week". So, you don't know about a basic chart pattern though you've been doing it years, and you take the p because you don't understand. That's sounds like an insult, but objectively, it's what you did, innit?
The value of the comment, is that you take advantage of it by paying attention to look for the break, if there is one. See?
He said a load of other analytical stuff, you're picking on one bit and deciding it was wrong. Seems to be your proclivity!
Dunno why you're holding gold it if you were so sure it would drop - or were you short?
That "guidance" I noted was about right, 3 buck profit on AMD, and they got the low of the day on Tesla within one cent. Usually it's more clear though.
I took a bit of that but used oil mostly, as the leverage is higher. Most of the pot went to oil which split long 1.7%, twice, x 10, plus a bit for DWAC which was going nuts. The TraderTV is good for alerting to things like that. So about 40% on the day.
Yes the leverage on gold is higher but the spread's rather wide compared with the movements - it never really appealed.
How did you do?
You mentioned TSMC, which all day today. Pity you sold. Could get attention tomoz.
Btw where do you stick your capital? I'm big in India and Japan for the moment.
Some interesting stuff is being said about oil and rare earths: https://oilprice.com/Metals/Commodi...Earth-Policy-Shakes-Global-Tech-Industry.html
How did you do?
