C
Coniferman
I have a standard looking stop cock under the sink. Probably 30/40 years old. I remember it always being a bit hard to turn but it always used to turn around multiple times. It will now only turn about 180 degrees. This does seem to give a full range from off (if quite tight) to fully on.
To be honest, it has been like this for a while. Should I be overly concerned about getting it fixed? Will it likely need an entire new tap or just a replacement mechanism? Is there a possible fix - like loosening the nut temporarily? Thanks.
