I've got what has been described as a 1970'sstype incoming black plastic pipe that has a stop tap attached that has a 15mm connection, I need to increase this size to 22mm but I have two problems:
I can't locate the road side valve to close my supply - Thames water are coming to help with this
What kind of stop tap do I need to change it on this pipe? Will a normal 22/22 with compression fittings work?
