Strange noise from heating
7 Feb 2007
Bath
I have a "brrrrr"ing noise coming from my heating. However, this has only occurred since I drained down the system and installed new TRVs and Lockshields on all the radiators.
It is a sealed pressurised system and I cannot work out why it has suddenly started doing it since being re-filled. I think maybe there is air in the system but I have bled all the radiators and all the other bleed valves and yet there is still the same noise. If the hot water system is active at the same time it doesn't occur but then the radiators don't seem to get hot either. It's driving me mad! I can't work out what's wrong... If just the hot water is on then there also is no problem. Any ideas anyone?
:lol: My wife is more of a "nagging" noise to be honest when I won't put the heating on. Of course it's even worse now there's another noise :(
Thanks for the suggestion but what do you mean by check any zone valve is operating correctly? Do you mean the motorised valve? Or the bypass circuit?
Did you fit an auto bypass valve?
Are there TRVs on ALL of the rads?
Put ya coat on sweetheart I'm goin to tha club ......... Woo ya haven't took me out in weeks...... I'm not ..... But I'm turnin the heatin off while I'm gone
The motorised valve seems ok, I've checked it out and it seems to divert as expected.
The hall radiator doesn't have a TRV, it has a room thermostat instead. There is a manual bypass. But I haven't touched that, it is just a tap, I could try turning that on a bit more I guess but then I would assume the heating wouldn't work at all when the hot water is on? I also have circulation problems, it needs to be very finely balanced or the furthest radiators from the pump don't get hot. I would suspect turning the bypass on would mess that up.
The noise today sounds more like a water tank filling, the same kind of rushing sound.
Just been playing with the bypass valve, I can eliminate the noise by opening it a little but then the furthest radiators don't work :-( Seems to be something to do with the flow. Would noise reducer do any good or is that just for the actual boiler itself? Only other thing I can think of is an automatic bypass valve rather than the current manual one.
Any other suggestions greatfully received?
