Strengthen notched joists?
30 Oct 2013
I am about to remove an old cast iron gas pipe running under the upper floor of our 30s house. It's all been disconnected from the gas mains so I just need to take it out and can then fix the floor boards that we're bouncing on it.
Will I need to look at strengthening the joists due to the notch left by the pipe or is it likely to be ok?
Cheers
Stuart
That depends on;
the depth of the joists;
the depth of the notch;
whether the notch is on the top or underside;
the position of the notch along the span.
I ended up leaving the pipe in. There are notches for gas, water and cabling on those beams but they are pretty substantial beams (about 9" at a guess)
and it's been fine all this time so probably ok.
