Strobe light?
Gyroscopic speed i used to be intrested in, helpd to see when the gyro was going to "topple" or go in to "gimble lock". Geek :?
Theres more things to worry about nowadays than actual fan speed.
Thought you had one, Tony?
I had one, used it a bit then lost it so bought another very cheaply. I found it easiest to either use contact method on the end of the spindle, or use a blob of tipp-ex & optics, by the way.
More useful on pumps, (screwdriver through hole) which the mfrs DO give rpm for. They slow down as the capacitor dries up and the slip angle increases.
Then I lost the second one.
The nominal speed of a simple spm is of course 50 x 60 = 3000rpm , though they "slip" so you typically get 2800 - 2900.
What I found for fans is, that you can usually slow them down a heck of a lot before the APS stops working, except for Ferrolis and I 've forgotten some ...
many years ago, with BG, had a prog on laptop that measured pump speed/performance with thingy/widget/wotsit placed on pump head. Proved quite useful at times (when it worked).
Do they still have it, in updated version.
The "slip" on a shaded pole motor can be quite significant.
Its affected by the flue length etc.
I am currently putting together a case study of the problem which prompted this posting and will publish in the CC when its ready.
The BG program calculated the expected speed of the pump rather than any actual measurement of the real speed as far as I can gather.
Tony
BG limpet programme could tell you just about anything about the pump right down to wether the impellor had come off the shaft.
Strobe light now that takes me back to school disco days.
Limpet, thats it, the only other thing on laptop was druid. The laptop was virtually indestructible, flew off van roof many times. Still got some old druid discs somewhere.
Yeah i kept a load of the discs too but no use without the build disc unless your a computer geek.
There was a guy in local part suppliers who used to buy set of discs every year for 100 quid, dont know how much he paid for the laptop but they where worth a few quid in those days.
I'll try loading my old set onto vista, have to re-date pc to match disc, should be fun.
