Evening all,
I need to get some form of structural survey done but need clarification on what im asking for before I ring round local companies.
So to understand where I'm at, I would like advice on a couple of walls and a chimney stack. One of the walls is actually like an archway (large), and only supports a stud wall above it and runs parallel to the existing joists upstairs, so I assume this can be removed as it's not load bearing (correct me if I'm wrong). The second wall runs perpendicular to the joists, and supports a solid wall above it, and has a chimney stack integrated into it (both of which I want to remove)
I have been into the loft and it seems that the stack and the wall are separate, which suggests that the stack doesn't support the roof (as you can clearly see that is done by the wall).
Obviously I am not even close to being a structural engineer so need advice before I will be doing anything. My main question is that when I have been looking at various local websites, a structural report seems to be geared towards an existing crack or structural problem. Therefore I'm not sure what it is I need or should be asking for.
Hope you can help.
Cheers,
Paul
Hope you can help.
Cheers,
Paul
