Struggling to find a replacement drain cover?
31 Aug 2010
Essex
Hi
We have what look to me like standard drain covers and sleeves from around 30 years ago. They are concrete and the cover part is roughly 540mm x 695mm in size, I've attached an image.
I need to replace the cover part only as we are building decking over both drains, but can't seem to find the right size, very frustrating.
Please help.
23 Jun 2013
Manchester
Think I'd be inclined to either leave things be and build a trapdoor cutout from the decking or remove the existing covers and frames and build up with new covers at the same height as decking.
Not sure what you're trying to achieve, op. :confused:
31 Aug 2010
Essex
I'm going to build into the decking 2 access hatches, but I will need the drain covers to be lite, the concrete ones are a nightmare already let alone when the deckings there.
The deckings not a problems its the replacement cover that is :0)?
31 Aug 2010
Essex
Dex, what I'm trying to achieve is to find replacement drain covers, its not a question about decking?
8 Jan 2005
Bath
What not buy a lightweight cover and frame and change the lot. :rolleyes:
23 Jun 2013
Manchester
Okey dokey. In which case it's probably be easier to find a lightweight cover with frame, remove the old one and setting the new one (possibly lower down by a level of bricks) in situ-cast concrete. Sounds a lot harder than it is really. :)
31 Aug 2010
Essex
Man this is hard work, the decking will be 600mm above the cover and the covers are heavy concrete, whether it has a concrete or metal or plastic or whatever cover clearly I will be including trap doors, I have already said that.
The issue is that the weight will mean only having vertical access a nightmare, I was just trying to source a metal, or other lighter alternative to the concrete.
Are we saying they don't exist?
31 Aug 2010
Essex
The rectangular access and cover, sit on a circular chamber, which are cemented together and reinforced. Trust me either it stays as is or I just replace the cover, they are the only options, a new complete replacement probably won't fit anyway, they are to small.
23 Jun 2013
Manchester
Well make one out of timber/ply/plastic then. FFS, they're only metal so you don't fall through them which you ain't going to do as you have decking over them
8 Jan 2005
Bath
I haven't needed to raise my covers in the last 45 years. :mrgreen:
It's not exactly a regular exercise, or is it
In any case why not just smack all the concrete out and just leave the steel lid.
8 Jan 2005
Bath
Gonna make the Barbie interesting building a deck over the inspection chamber :LOL:
