This is about awkward parts in the peugeot 206 which is fever 1.4 i 04.
What trying to do is replace spark plugs and to do that have to remove iginition coil, but to do that need to remove the 10mm nuts so go with socket set and try it , it wont budge with wd 40, tried 10mm spanner it simply wont budge, the 10mm socket dont budge it, what will get this nut loose. The reason the sockets dont twist the nut is because a stud sticks up and blocks socket.
Next is the door panels which have allen key heads the bolt heads do but the bloody things are webbed so they wont budge so now what, how can get them out.
Trying to put lockwood dials dash in but the same problems allen key bolt head is webbed so its impossible to get it out.
Havent got the money for flash parts just spent a fair amount on socket set, which useless
