Stupid grouting question
29 Apr 2007
Berkshire
Yet another stupid question from an extremely novice tiler lol. I have done a lot of tiling lately as I have moved house and I have the most ridiculous question that you lot will take the mick out of.
Whenever I grout for some reason no matter what grout I use or how careful I try to be the next day I always have a row of little like airholes in all my grout lines. What the hell am I doing wrong ?? I have even had a friend have a go but the next day the tiny little holes were there again.
Alan
Yeah you often get that with pre-mixed grout or that God-awful grout in an aerosol :eek: What grout did you use?
It sounds like you are using too much water to wash the grout off, or you are mixing the grout up to a consistency which is too thin. It should be similar to toothpaste or peanut butter. When it comes to washing off, you should use a good grouting sponge and make sure you really ring it out so that it is just damp.
I use these Super Hydro sponges:
http://www.tradetiler.com/acatalog/tradetiler_tile_cutter_grouting.html
Too much water = lots of bubbles.
In regards to what grout to use, I find that BAL stuff is very good. I have also used Mapei and Ardex without any problems.
CivilianJenny said:
It sounds like you are using too much water to wash the grout off.....
Yep this is a possibility too if it's a powdered grout. The bubble marks you speak of are usually very small and can normally be rubbed away quite easily.
