I have just done something really stupid.
I was working in a tight situation with virtually no 40mm PVC pipe left sticking out of the wall to bond to. I cannot get at the pipe at the other side of the wall without taking the bath out! I was extra careful because of this and took great care over the joints.
However, after completing the work and the pipes are now welded, I suddenly remembered I had pushed a plastic carrier bag into the pipe to stop the drain smell while I worked.
It was a long run of pipe so I drilled a neat 3/8 inch hole into the 90 deg bend at the centre of the bend and was able to pull the bag out. Now I have a 3/8 hole in the bend. Can I convert this to something like an inspection point or is there anyway I can seal the hole.
There is no 40mm pipe left to attach to if i simply cut off the 90 degree bend?
