Good morning!
Hoping to get some advice from someone more knowledgeable and experienced than I am.
I have a 100A PME supply to a garage.
I am providing a new sub-main to a new studio/workshop which is about 30m away from a garage CU. I have run the cable through underground ducting and already backfilled the trench. The cable is 16mm 3C SWA.
The plan was to EITHER split the meter tails and provide an independent supply via an 80A switch fuse OR fit an 80A MCCB to a spare way in the existing garage CU. The studio will have a 100A DP isolating switch with all circuits protected by RCBOs.
The SWA cable has a maximum rating of 91A and I designed the installation on this basis. I realise now that the cable won't be able to take this load in practice and I think I will have to downgrade the design load from 80A to say 63A.
Needless to say I'd rather not do this unless it is strictly necessary since it will invite all sorts of difficult questions!
Like I said, I'd be very grateful for some definitive advice as to what load the existing 16mm SWA cable can safely take.
Regards
J
Regards
J
