Hi, sorry if this has already been answered in another post, but I've been searching this to death and can not get a straight answer!
We had laminate flooring in our living room, dining room and hallway which we have taken up some time ago. Underneath the laminate was mostly parquet flooring, some areas had been cemented over due to work done on the radiator pipes in the past.
As we want to put solid wood flooring down in these areas, we decided to take up the parquet and prepare the subfloor with some self leveller and liquid DPM. As things are at the moment, the concrete subfloor is covered in bitumen with most of it covered in dust and small stones and even some small bits of parquet wood stuck to the bitumen in some areas.
Now in terms of what products to use on the concrete subfloor, I have spoken to someone from a certain company (not sure if I can mention company names in this post?) that has given me some suggestions as to what to use for damp and for levelling.
What I have had conflicting advice on is what to do with the bitumen?
On the one hand I am being told to get someone in to completely remove it - 'mechanically prep' or 'mechanically remove' it with a diamond tipped cutter. That if you don't remove 100% of the bitumen it will be a weakness in the subfloor and eventually we will have problems with the wood flooring.
On the other hand I have also been told it is not necessary to remove the bitumen, simply to clean off the dust and apply an adhesive before laying the levelling screed.
Can anyone advise me which is the correct answer?
I thought that to lay any screed down the subfloor must be completely clean and dust free, which as I have already mentioned, ours is not as all the dust has stuck to the bitumen and would be nearly impossible to remove.
Another question I have is with regards to laying the screed down. Our living and dining room is open plan but we were thinking to lay the screed individually in each room because of fears that the screed would dry out on us too quickly (never attempted to do this before, so maybe we won't be fast enough?). Does anyone think this is a good idea or would you say to just do it in one go?
In case anyone asks, we have already moved the radiator pipes above ground and the house was built early to mid 60's.
