I build a shed last year - flat roof.
At the back I decided to fit a drip edge into a gutter. The beam the gutter was attached to has warped over the summer, lifting the gutter in the middle and pushing against the drip edge. The drip edges were nailed to the boards with long felt nails which were then covered with the roofing felt.
The movement has resulted in one of these nails where the two pieces of drip edge meet, being pushed up - almost all the way out, so that there is now a bump in the felt above. I'm going to remove and refit the gutter, but can't think how to deal with this nail. I can't just push it back in without using a hammer, and to do so would damage the felt and the felt is glued to the drip edge so it's not going to lift easily until I'm ready to redo the whole roof.
All I can see I can do is to hammer it in (or cut through the felt and remove, and then patch the felt with a new piece on top and plenty of adhesive.
Thoughts?
Thoughts?
