Supplementary bond to junction box
20 Feb 2008
Birmingham
Dis is getting to be a habit!
Although towel rail is possibly on the blink (see early post) am continuing with planned work and installing supplementary bonding or at least putting in missing bits (to light and towel rail circuits) .
Said towel rail is on a spur which breaks into ring via a 30A junction box, box is under floor near to FU, am I ok to connect bond (4mm) to this, saves me hacking out plaster to get to FU.
Also noted FU has no earth to metal back box - does it have to have one?
Is it an electric heated towel rail? If so, why does it need supp. bonding? It's earthed isn't it?
One of us as got this wrong and I am trying not to get confused! I am working to 16 edition since to my understanding 17 effects other areas which I dont want to get involved with Ok it could be me but please confirm how your views tie in with
http://www.diynot.com/forums/viewtopic.php?t=130912
also
http://web.archive.org/web/20051231060046/http://www.niceic.org.uk/downloads/NL139supp.pdf
My understanding is that all circuits have to be bonded together whether earthed or not (e.g. also shower and lights which are both earthed) plus pipes. Towel rail casing does not have to be separately bonded towel rail circuit does.
Grateful for any clarification
Dont want to make believe I know anything about 17 edition, because I don't but have noted one post for those who want technicalities:-
http://www.diynot.com/forums/viewtopic.php?t=131614
If nothing else in my case lighting is not on RCD so if I understand things correctly bathroom lighting circuit would have to be reconnected in consumer unit, job then becomes notifiable under part P - whereas supplementary bonding does not; bonding in that sense easier/cheaper. I have no idea whether under 17 edition supplementary bond can still be fitted - others will know (?)
Trust if I've got this wrong someone's gonna tell me!
