I also have a Suprima 50 which is misbehaving.
Problems arose after adding an extension to our house 2 years ago (one room and 2 rads T'd off existing circuit). About 4 months ago the pump failed - I think this was clear-cut in that we awoke one morning to find a dead boiler (fuse had blown) and the pump had fallen apart inside (water in contact with electrics). Since then boiler cuts out as described above and responds to reset. So far its only about once a week but seems to be getting more common.
A new problem however has surfaced. The CH is switched off at the timer due to warm(ish) weather so only HW on at programmed times. In the last few weeks, I've noticed that the radiators are warm. I presume from what I've read that the 3-way valve is faulty. So what do I replace and in what order?
1. 3-way valve?
2. Motor for valve?
3. PCB?
D.
MOD
please see item 20
your post has been split
1. 3-way valve?
2. Motor for valve?
3. PCB?
D.
MOD
please see item 20
