Sure Stop....y or n ?
27 Jul 2006
I need to replace my stop cock as i'm fitting a new kitchen and was considering the Sure Stop.
I believe initially, Sure Stop themselves suggested keeping a traditional stop cock also (makes a but of a mockery of the word *Sure* in my mind) but now, i believe they are saying that they can be the only method of shutting off the water
So what's the general feeling.....
Are they reliable or still a bit of a fad and thus, best to be safe and stay traditional ?
It is a useful invention.
If you're elderly with arthritic hands and a stop tap in an awkward place, go for it. If none of these apply, save your money and fit a standard stop tap.
We fitted one on the pipe leading to the outside tap after it froze/cracked one winter, so we could isolate the tap in winter.
Had a leak from the SureStop a year later.
It's a useful invention but I wouldn't rely soley on it. Fit a conventional stop cock, and then add the SureStop in the line behind that as an easier-to-access/use means to cutt off the supply.
Tht way, any issue, you can still fall back on the stopcock.
then a lever valve is fairly easy to grip and use. You may be able to hook several fingers round it, or push it with your palm.
ae235
I don't know if you can get them with extra-big levers, as often found on gas valves.
I've also used the T-handle ones, but they are not so easy to operate with your fingers
As an interim step you can get a stopcock key that fits over a T-handle, and hang it within easy reach (there is also a much bigger version, useful if you have a stopcock in a pit)
ae235
