I am not sure if this is best in here or the general building section but here goes.
I want to install a suspended timber floor in the small front extension area that will sit "within the house". The area is 3m x 1.5m. The ground level sits approximately 450mm bellow the top of the proposed joist.
Assuming i use 6x2's for the joists (This appears to be more than enough for a 1.5m span but will it give any bounce?) this leaves circa 300mm between the underside of the joist and the ground level.
From what i can make out i am then required to provide 150mm of free void space to allow venting to prevent the timbers being compromised by any dampness.
I think the above is correct and in line with what the BCO expects but it is the next step that confuses me. what is required to "cap off" the ground. In existing rooms there appears to be 50mm+ concrete oversite and thats it but the house is 100 years old. What do i need to do?
Can i just lay 50-100mm Type 1 and compact. Am i right in thinking this layer is not to provide damp proofing as you have the vented void and just to stop growth of vegetation?
Help and clarification much appreciated.
