Swa extension
8 Feb 2025
Sister don't use forums needs sŵa extension for new detached annexe replacing old one electrician told her he'll use gel filled joint, quick and easy, presumably they'll last for ages
Is there a question there?
Gel, is not a usual means of jointing SWA.
I don't understand.
You've got someone who is committed to using as few words/punctuation as possible, asking for advice on how to make a high power capacity underground connection. Advice that they will then pass onto A N Other non-sparky to follow..
In my book, a post to avoid responding to entirely!
He meant resin filled , which is fine.
You cannot even read his simple question, ...Will a resin filled joint last for ages... its a simple question ... answer yes
Trolling people who ask a simple question simply , the op came here to get an answer because he was unsure if the proposed solution was good... not a lecture on standards of their vocabulary, punctuation or some clown who cannot take 30 seconds to read his post, implying that he was doing something he shouldn't...
Have the moron class on here forgotten what this forum is for... to help people or do they think its just to get their jollies running people down ?
Moron class?
I am highly educated and come here to give my time and advice free of charge to help people.
I get no "jollies running people down" as you put it, but when I get a garbled message I do not understand, I say so and expect the OP to rephrase what they said so it is at least understandable.
Gel can be used in jointing cable, so if they are indeed talking about resin, it's important to make that distinction.
That is not unreasonable.
Just wanted to know as I'm alayperson, first time been trolled what's punctuation got to do with it do you have to have o level English to post get back in yer cave or be turned to stone take yer pick
Not o level, but simple, basic English, and an attempt at punctuation, helps make your question clear for the reader. What you wrote, didn't even pose a rational question.
You are not being trolled, you are simply being asked to read through what you write, and check the meaning, and the question is clear.
Neither.
I shall just refuse to help a rude ungrateful person like you who has no understanding of what people like me are doing here.
You don't need 'O' level English to post, but it was more than just punctuation. All I asked was for you to make it understandable. It's not a big ask.
You are henceforth on my ignore list.
For heavens sake.
OP has been told by the electrician a gel filled joint (presumably a wago device in some way) which has become a very popular alternative to resin filled joints.
The question is simple.
