SWA for garden lights
17 Feb 2004
I need to connect few garden lights supplied by SWA. does some one know a small connection box that will allow loop in/out and being berried?
http://www.tlc-direct.co.uk/Products/SWJKT1.html
How much room is there in the base of the light itself?
A galv conduit trouser box, two CW20S SWA glands and a 20mm stuffing gland for a 3C flex out the top is what is usually recommended if theres room in the bottom of the column
firstly, thanks for the replies.
yes I used the "breech joint" in the past to extend a SWA cable but I do not remember whether it has a third exit for the light fitting supply.
As I pass the cable in a duct (the cable is 3 core 1.5) I can choose a reasonable duct size to allow a small connection. I can come up with a T connection on the duct up to the light fitting point.
I am asking for a connection that can be berried as i am not sure if it will be accessible after all is finished.
Yes, as advised, i considered a black rubber flex from the SWA connection to the light fitting, I just need a connection with 3 in/out points.
Well I may have misread your post, but the resin kit I linked to has 3 entries so would be suitable for your needs. If I have got it wrong and it is not suitable even with the 3 entries then just ignore me :lol:
Thanks, I hope you are right and my memory is bad...I will check it
