BR said:yes SWA can simply be burried straight. The exact regs for britain i cant help you with. 0.5m sounds fine.
chowbasa said:What about installation Method 1
FWL_Engineer said:all cable that is burried should be a MINIMUM of 450mm below the surface, should be INSIDE ducting and should also be bedded in sand or builders gravel. This should be CLEARLY indicated by marker tape stating
CAUTION. BURIED CABLE
Anything less is a cowboy job.
FWL_Engineer said:BR said:yes SWA can simply be burried straight. The exact regs for britain i cant help you with. 0.5m sounds fine.
EXCUSE ME..you do not simply "chuck cable in the ground", all cable that is burried should be a MINIMUM of 450mm below the surface, should be INSIDE ducting and should also be bedded in sand or builders gravel. This should be CLEARLY indicated by marker tape stating
sterose said:Forget the ducting, just make sure you bury it plenty deep.
Only cable meeting the requirements of BS5490:1977(1985), BS5593:1978(1991), BS6207, BS6346:1997, BS6724 : 1997, BS7889 : 1997, shall be used for external purposes where such cable is to be buried in the ground. All such cables must be enclosed in cable ducting manufactured to comply with BS EN 50085 and BS EN 50085-1 : 1999. Such ducting must be laid upon a bed of sand or similar material which must have a depth of not less than 100mm. The Ducting must be covered with a layer of sand or similar material having a depth of not less than 100mm, this sand or similar material must be identified in accordance with BS1710 : 1984(1991) using indication tape manufactured in accordance with BS 5378-1:1980 which must be a minimum of 450mm below surface
