Hi All,
I want to run some SWA cable from the meter via a connection block and switchfuse to a second consumer unit. I shall be using 16mm2 cable. Should I use 3 core, L N & E then connect the wire sheathing to the earth core or can I use 2 core L & N and use the sheath as the earth, with, of course the correct glands and earth connectors at each end?
Chris
Chris
