Can I substitute two 6mm2 t&e cables in place of a single 10mm2 t&e cable? I need to run approx 4-5m from my old CU to a new CU in my extension, and the electrician has specified 10mm2.
That's fair enough, but I have half a drum of 6mm2 cable in my shed, and although I understand that the load carrying capacity of 2x6mm2 cable exceeds that of a single 10mm cable, there may be other restrictions.
If you don't mind I'd like to ask a couple of questions.
1. I now have an isolator switch next to my meter, so I can safely isolate the old CU. What's the best way to connect the new CU? To the isolator switch (doubleing up with the old CU tails), or piggy-backing onto the bus-bars in the old CU? Obviously, if I connect to the isolator switch, then I'd need to run new meter tails to the new CU, rather than T&E.
2. What is the best solution for running through 20/25mm conduit? 10mm t&e? 2x6mm t&e? 10mm singles? 25mm singles(meter tails)?
many thanks
Guy
many thanks
Guy
