Swapping a same sized rad.
16 Jul 2009
Hull
If swapping a same sized rad. So not draining the system and just turning off at the valves. Are new tails needed or would you remove the tails from the old rad and refit? So they bite up correctly to the existing valves?
If the old rad tails are slightly unusual I would remove them and use them as they match the original valves.
If they are in good condition and easily removed is another reason to reuse them
