Hello all
Ok lets hope i may glean a way forward from all you helpful people!!
I have installed a quite old swiftflow 80 combination boiler, The thing runs well and still looks like new..However!! Some time ago I was not getting hot water, central heating was fine but no hot water!! as my utility sink, the fused switch for the electric to the boiler and the wall mounted boiler are all in the same proximity, I found that if i flicked the power switch off and back on , and then turned on hot tap , the boiler fired up and all was good...However.. as the hot water was flowing it would go cold (basically the flames were reverting back to standby pilot), this sort of cured itself after a few days and have had hot water since!! Until Now!! same problem but getting worse.. can still get water by on and offing power to the boiler (not sure what this does to help though) Suspecting its the flow switch as there seems to be a clicking at the bottom left of boiler were flow switch is located... what i wouldnt mind is if somebody came up with a sequence of checksto determine the proble..
All help gratefully recieved!!
Russell
Russell
