switching between 2 sockets on a timer
So you have a 2800W (240v) kettle, and you want to drive it at 12volts. Well I get 7watts from the element, so it will take a while to boil the water.
The specific heat of water is 4.19J/gK.
1W = 1 joule/sec, so a 2800W kettle delivers 2800 per second, and a 7W one delivers 7 per second.
If we assume 1l of water to be raised by 90°C we need to put in 377,100 joules (assuming no heat losses during the process).
So with that assumption (which will be false in practice), a 2800W kettle will do it in 135 seconds. In practice a bit longer, but not much, as heat will be going in much faster than it is being lost,
A 7W one will take 15 hours. In practice I'd wager that "never" would be what happens.
Agreed. It might be feasible to maintain a certain temperature of water rather than heat it up in the first place, but I suspect with that kind of heating power, even the temperature it could maintain water at wouldnt be that great. Probably fall well below boiling temperature.
Thanks Ban All Sheds for that nugget of wisdom.
My Science teacher said that a joule was the same amount of energy as it took to wiggle your big toe (dam all). Can you confirm the truth in this statement?
