Switchmaster blue actuator
31 Oct 2008
West Glamorgan
hello
My blue switchmaster av1 midi valve actuator as seen better days. It's now been fitted with a Landis & Staefa Mav 322. The plumber could not wire it. I have contacted an eletrician who can connect it up because I have no wiring diagram I also found out that the above model is not made anymore. My timer is a switchmaster 900 where you set the toggles for switching on water, heating or both. Would anyone have a wiring diagram so this can be connected.
1) Why have you used a plumber who can't do the job?.
2) Why has he fitted an obsolete part?.
1) Thats what i thought!
2)blue switchmaster av1 midi valve actuator, is the obsolete part
I hope you still have the switchmaster wired in as it will make it really easy for the spark
Switchmaster ............. , , landis
Blue ....................... blue
green/yellow.................... green yellow
yellow........ ..................white(poss brown if no white)
white................................ grey
orange/ red link together................orange
Should have read more carefully.
