synchro motor
21 Mar 2009
Lancashire
needed to change a synchro motor today on a siemens 2 port motorised valve. got it all set up but the spindle from the driving motor was too short to engage the valve, has anyone else come across this? i thought all synchro motors were the same?
They are in this case, your not engaging it proper it will be pushing the rack away
SECO what valves have you found a standard motor wont fit, i have never came across one out of all the makes even those your not meant to change just the motor.
Not saying your wrong ,just asking
im trying to find it now i remember having one and i had a motor i took from a honeywell when i tried it the spindle was to short.
just can't think what valve it was.
definately fully engaged, i managed to get it working by washering the back of the new motor to build it up but it looked a bit bodged so have ordered a new top. got the old and new synchro here and there is a 3mm difference in spindle length, bought it from a non english plumbers merchants so is probably imported muck.
Neva had a prob with a standard synchron in a siemens or original landis valve although they are sh@te valves.
black plastic. got called back this morning, no hot water. must have accidently disengaged the motor housing whilst working on the heating valve so was just spinning on nothing.
i hate plumbing :cry:
sorry to drag this up from the past but thought i would let any plumbers know who might come up against it.
got the new top for this valve and there was a warning inside saying "if valve that is being replaced has green fixing lugs please remove 2 springs from body" did this and original valve head worked without the clicking
just incase anyone ever comes up against this crappy valve
they just seem to push the housing up from the body and then you pull down the lugs to lock the body to the motor housing.
i fully replaced the central heating valve with a honeywell as the last few ridges had been worn away as the motor was constantly turning on them without engaging fully.
