Contact systemlink would be the best option.
If you're handy with an arc welder you could make yourself one of these. Its basically a glorified low loss header.
Hi yeap,
used to fit them in Ireland as they were made in dublin.
Handy with the welder but not sure how the baffles are laid out in it.
We found they were better than building a large low loss header.We also found that it neutralised any heat up problems with pellet burners as they had to reach 60 deg before shunt pump would run which was not a problem if we had oil or gas boilers connected to the other inlet ( saftey condensation mode ) as this sorted out any volunm problems with under floor heating.
Wanted to try a system zone on a project here with a pellet boiler only to see if it could overcome circulation and temperature problems with this type of boiler
