I have two taps that do this and after 12 years I am fed up with taking them apart and putting them back together - what the heck is the cause ??
The two taps are on gravity fed HW - so they get opened all the way on each use, to get the required flow. Since our cold water pressure is high, the opposite numbers (cold) never get more than fractional opening and they have no problem.
Symptom is that over the course of a month or two the number of turns available in the tap mechanism reduces. I then dismantle and reassemble and all is well for a few months and then we do it again.
I assume / the thread inside is unwinding and I can only assume this is because the hexagonal section is clear of it's housing and therefore the thread can spin freely. But I don't know - hence this question.
Is my diagnosis anywhere near ?
Is there a solution to this ?
Thicker tap washer maybe ?
Thanks so much in advance.
