tap connecters
What sort of tap connectors?.
3/4-1/2" endfeed.
Compression flexi's
1/2 " the sort that fit on the bottom of the tap and have a sort of olive on them. im no pro but last time a recconected a tap i couldnt get it to stop leaking without putting ptf tape round the olive thingy
Standard copper tap connectors should only need a new fibre washer to make good seal. Speedfit or the like have rubber seal built in that should be watertight at hand tighten only :roll:
If the taps have 1/2" BSP thread then they will have fibre washers.
Before you make the connection, soak the washers in a little water, pop them in the fitting and nip up (dont over tighten). They leak when you crush the washer :wink:
Sounds to me like he's used nuts and olives.
Brilliant idea so use a little jointing compound.
Tip: you can get nylon versions of those washers, and they're blooming marvellous.
Cut the soaking out = time and money :idea: :roll:
Will have to drag myself screaming and kicking into this centry :lol:
And if you're out of daub you can use jointing compound to stick your wattle together forsooth.
Light a candle for me, mootha - I'm putting the dogs oot and then I'm off to bed.
