Tap connector
4 Jan 2006
Yorkshire
Anyone know who sells 22mm x 1/2" bsp bent tap connectors, it's for fitting a rainfall shower head and the manual says to use 22mm pipe where possible. I could reduce down to 15mm and use a 15mm bent tap connector but thought this would cause a restriction and reduce the flow.
you can't fit the shower head etc until tiled and finished.
Not fitted permantly at the moment, I've fitted a joist at the shower head height and grafted in a piece of aluminium for strength then I mocked up the thickness of plasterboard and tiles using a piece of wood. The outside of the stud wall will not be plasterboarded until the inside is finished and shower head fitted.
so you can get rear access to fit shower head after tiling etc, then fit plasterboard to other side.
