Bought a low projection "Impulse Unispace" basin with 1 tap hole for a wc i'm constructing.
Tried my fancy monobloc mixer I bought for my en-suite on it just to see and the base was too wide so that when the tap tails were attached it wouldn't fit.
Not a problem as I was planning on buying a cheap regular mixer for it, bought this. http://www.toolstation.com/shop/Tap...s+Mixers/Barra+Basin+Mixer/d240/sd2691/p62574
Same problem, hole not big enough to allow two tap tails and the fixing bolt to go through the hole, even if it did the tap wouldn't sit flat on the sink.
Called the manufacturer to ask for the names of some taps they know fit, apparently it's a "british standard hole" and I need to speak to wherever I bought it. I pointed out their brochure/website has it with a tap attached, "that's just a photographer that's done that." was the reply.
I'm thinking maybe one without the pop-up waste part might fit as the tails and bolt would be more centrally located on the tap base. Or I could grind out the hole bigger in the sink?
Any help would be appreciated!
