Tap Problem!
12 Nov 2008
Hi all, im an amatuer at this but i have an issue with a tap of mine that keeps leaking. I cant seem to get the cap off .
Its a Q-TURN SINGLE LEVER BASIN TAP
Any help would be appreciated!
James
Usually you remove the cap on the top of the tap and unscrew the the small brass scre inside to take of the tap head.....use a stanley blade to pop up the cover.
Note you will need a new 1/4 turn insert (or new o rings.....very fiddly) to stop the tap dripping
Thank you! the top cap seems to be the problem so far. Its kinda stuck in there :( Ill keep trying!
Hey guys....as advised above i tried to remove the top cap where the brand is & as i guess theres nothing below it. Thats just the brand. Im suspecting its a either twisting method or a lifting method. Anyone??? Any idea?
James
is ther a tiny hole or cap at the back of the tap handle body. wich could mean its held on by a grub screw, usually small allen key or flat head drive will fit.
i just checked . there is none :( Its just two piece in total...one is the lever & the other is the tap itself. Thank for your time :)
could be the bottom ring is holding both together on the tap handle. try holding the main part(long handle) and undoing the small lower ring.
Thank you for the help. the lower small ring is connected to the upper piece. Its 1 piece in all. That is if i got u right.
