Tap surround leaking on water butt - how to seal?
10 Jun 2010
Hampshire
I've noticed that the tap leaks on a second hand water butt that I've just connected. The tap valve itself is ok (you can turn it on and off) - it's the seal around the tap that is leaking.
It's a plastic water butt with plastic tap. I'm thinking of using a seal or something, but I'm not sure what to use. I don't want to glue it in.
The butt is 200L, so it's deep but is roomy enough to be able to reach in and access the tap.
Unscrew the nut on the inside of the tap (inside the water butt). The tap then pulls out. There is a plastic washer on both sides of the hole. I bet you'll find one or both of these has hardened and cracked/broken. Replacement washers are easily obtainable (B&Q etc.). Clean around the hole before reassembling. Maybe add a small bead of silicon for belt and braces.
