- Joined
- 17 Sep 2008
- Messages
- 41
- Reaction score
- 0
- Country
1) I bought a sealed plastic pack of replacement tap washers from a DIY shed which where labelled 19mm. But when I measured them they were 25mm in diameter. Was this simply a packaging mistake or what?
2) I've replaced the washer in an old-fashioned tap in my 1930s house. The old washer was 20mm in diameter: the last time I replaced it I wished I had one slightly larger. Is there a standard size that's slightly larger than 20mm, some imperial size perhaps?
3) After replacing the washer, the tap still drips a little. The drips do not seem to depend on how firmly the tap is closed. I've unscrewed the top cover of the tap, and no water is leaking up there as far as I can see. I had to trim the 25mm washers with some scissors, but I still think I've got a good seal. Is there anything else that might be causing this? It is not just residual water dripping out.
4) Would it be a good idea to put two washers on the spindle rather than one? There is room.
