tapping pipes under floorboards
7 Dec 2005
I have just moved house. Everytime we have the central heating on there is a constant tapping from the a number of pipes under the upstairs floorboards. It is pretty much constant, it will go off now and then but mostly it is tapping away and is very annoying. Is there anything we can do?
The sound will be that of pipes expanding and contracting in tight notches under your floorboards
Suggestions In order of preference
Take your boards up and :
1 Cut deeper notches, or if you want to cheat>
2 Spread some talc around [I'm told this eases the friction] Grease of some description may do the same or
3 Turn your telly up so you dont hear it :evil:
If you can lay your hands on some scraps of felt (the brown stuff formerly used as carpet underlay and insulating wrap) try to put a bit of that between each pipe and the joist or board that it rubs against. You can't make felt rub!
Right on John...............it`s called tubular felt and it`s at plumbers merchants ..always used it under pipes ;)
Q. Where can I get felt?
A. At a plumbers merchants.
Good to know :LOL:
Good to know :LOL:
you could try Adam W`s Cottage ;) too :LOL:
many thanks for the advice, I will rip up the floorboards and upset the mrs!!!
thanks for advice on this one, i have pulled up some floorboards and found one of the pipes to be sat on the joist. i cut away at it so it no longer touchesd and this has cured it.
