- Joined
- 7 Mar 2004
- Messages
- 298
- Reaction score
- 4
- Country
I just fitted some new basin taps. There was no problem apart from the flexible steel braided hoses that appear to be a compression fit. When removing them, I was expecting a fibre washer or similar but instead, someone had applied some sort of sealant inside. When I went to refit the hoses, I wound plenty of PTFE around the threads (there was none when I removed the old taps), and tightened them up. The hot tap seems fine but I really had to wind on the nut onto the cold tap to stop it leaking. Is this a problem or is this typical? Should there really be a fibre washer?
