Guys
Have installed 2 X wall mounted ceramic disc taps as per this url:
http://www.plumbworld.co.uk/0000-376?eid=0013-000004
I have commisioned and cannot get any water flow out of the taps. I have loosened the compression nuts on the mixer valve that serves the spout & have water flow. Also undone the main body of the valve & again water is getting through. Have checked that the filter at the end of the tap spout is clear. Also piped correctly to the H/C inlets. The specifications advise min pressure of 0.2 bar. I have a Baxi Maxflow WM boiler Min DHW operating pressure 0.1bar & max Max DHW system pressure 8 bar with a flow rate of up to 16Litres per minute, so good pressure from the hot and the cold is served off the main, again reasonable mains pressure. Surely I have more than 0.2 bar? I'm bemused, could understand if it was 1 tap but the fact I have installed 2 side by side just makes me wonder maybe not a manufacturing fault & maybe I am missing something obvious?
