- Joined
- 27 Jan 2008
- Messages
- 29,662
- Reaction score
- 3,669
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I am on Octopus Go, not the smart version, and it does seem to work well for me. But there are so many tariffs, it seems near impossible to work out which is best.
It is not helped by the fact we can change when and what we use, to line up with the tariff we have, and also the inverters are often limited in what they can do, I can't even if I wanted, give control to my supplier.
The Smart meter is rather useless, as the most important fact I need to know is state of charge, if I could set my oil filled radiator to turn on at (set time) only if my state of charge is over (x kWh) I could use the energy, but any device which can auto decide when to use the energy, like my iboost+ is one expensive, and two a small change in tariff can make it redundant.
So in the main we look at what was included with our appliances, so my washing machine, tumble drier, and dish washer have a delay start built in, but my old tumble drier could be set and turned on with an external socket adaptor, so it was set to 00:30 and if the drier had been filled and turned on, it would start at 00:30, but the sequence of button presses required with my new one, is not that intuitive, and as a result I have a problem getting my wife to use it. And also tumbles the clothes every so often while the delay elapses.
So my wife will use it mid day using solar at 12p/kWh if not used, rather than over night at 8.21p/kWh and the difference is so little hard to say don't do that.
With other options over night is not cheaper than solar, so change tariff and we also need to change how used, so very hard to work out costs.
