telephone cable clips
8 Jun 2008
Bristol
I put the digger through my telephone cable, i have re routed/ new conduit and patched it all back together.
However i have used crappy terminal blocks to link the wires together..
I have seen BT use little discs that are filled with gel or something.
Does anyone know what they are called or where to get them from?
A
If it's going underground those little connections wont be enough to hold out the water. If I were you I'd nab a BT guy in the street and offer him £30 to put a joint on for you.
Hi Guys,
Well i salvaged the good end of the cable, threaded it through some conduit, which is stuffed into the old piece and back into the road.
I then chucked a ip66 box on the wall with some galnds on it, then thread a new bit of conduit through the ground to the house, with some new phone cable.
I managed to get batt cables to supply 30m of armoured phone cable. So all then links are above ground and if need be i can pull in new stuff as well.
Cheers
A
