Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Can anyone tell me what the average temperature of a panel radiator flow and return with TRV open fully?
I know the difference is around 20ºF but what are the individual temps?
It is there, if that does not answer your question, you are not asking the right question; if you ask exactly what you need to know, you will probably get the answer.
The correct answer to the question you posed is: (as in faq) 10-12 C.
Radiator outputs are specified with a flow temperature of 75°C, return temperature of 65°C and room temperature of 20°C.
Older, non-condensing, boilers usually specified their output based on a temperature difference of 11°C between flow and return. But modern condensing boilers often quote their output based on a 20°C temperature difference. The only problem with this is that the radiator output is then about 15% lower than stated in the manufacturers' literature.
excellent! Thank you very much for the information and thank you for answering the question I asked!!!!!!!
Got no idea what his problem is. Obviously the monkey in his signature!
Kind regards
